Megasquirt info
megasquirt Distributor Wiring
Tomo i am going to double check Dizzy wiring. I believe this is the correct wiring
B/W-12switch(make sure there is 12v while cranking)
B-Ground
G/B- To pin 24. Pull up resistor required
G/Y not used.
By the wiring diagram, notice the placment of the plug in the diagram. It is turned 90degrees with the "unplug" tab facing west.89' Turbo-R.I.P. (scrapped)
BLOZ UPSenior Member- 2971
G/B is the wire you need from the dizzy. It's 6 slots.
G/Y is the wrong one, it's the 360 slot one.BLOZ UP.com
Heres what sucks. The oem harness that plugs into the dizzy is not the same colors as the wiring diagram. Neither is a 92 pathfinder harness. THere both as follows
Red
Black
Green
White.
At the moment it is wired red 12v, black ground, Green to pin 24.
The harness i have and the Wiring digram dont even corolate together. black were G/Y is, Red is were G/B is ect…im going to try a few different things i guess.89' Turbo-R.I.P. (scrapped)
shromySenior Member- 2189
The pin locations should be the same in the connectors, so color wont matter.Hmmm, Whats next?
84ZXT -
but they arent. Look at the 300zx89 FSM and the PathFinder FSM. there different.
My harnees, 89300zx fsm, pathfinder fsm, all the pins are in diff locations lol. its like they just pinned harnesses blind89' Turbo-R.I.P. (scrapped)
Use the one that the G/B connects to.BLOZ UP.com
Well, Finally got something. Rpm is scatterd like no other. Here is whats odd: Turn key on/crank engine… When the engine is cranking the rpm needle on the gauge page, or the tooth logger does not read. When the key is let go from the cranking position the rpms jump up to 300+ and the tooth logger reads 1 blue line. then i turn the engine off and back on and the whole log is on the tooth logger screen. Not synced goes to signed for a split second and not cranking goes to cranking and it keeps going back and forth while cranking. This is very hard to describe so i made a video http://www.youtube.com/watch?v=jj8-GOWAjXc[/video]]. Notice how there is no rpm until i let the key go89' Turbo-R.I.P. (scrapped)
Take the dizzy out (but leave the harness connected/reconnect it), disconnect the injectors. It's much easier to see if you are getting an RPM signal by turning it by hand. You can get 2-300 rpms easily. Much easier on your battery.
Seems like it's not connected to the right signal line. You should get something while cranking if it's hooked up correctly, even if your grounds are bad. Also verify that you get ~12v on the signal line, works best with a analog meter. There is a pullup resister, right?BLOZ UP.com
Well i know what the ground is. ohm'ed that out. So we have 3 other wires to work with.
12v
signal
not used.
I did not depin any wires and flip them around. After the ground was omhed out the wire was in the correct spot already so i assumed the 12v was in the correct spot. I desolderd the green wire from the resistor (on the dizzys side) and soldered it onto the white wire and this is were it got me. Yes there is a resistor. With it wired to the green wire it does nothing.89' Turbo-R.I.P. (scrapped)
If the stock transistor/resistor is wired in then i should be able to run pin 36 on the main board i think. It wouldnt require the BIP373. Im not sure though. I hate wiring this to the ms3x. Anyhow, im wondering if this has to be done.
http://www.msextra.com/doc/ms3/ignition.html#vrv357pull89' Turbo-R.I.P. (scrapped)
Where is your pullup?BLOZ UP.com
In line. on the signal wire89' Turbo-R.I.P. (scrapped)
connected to that and a +12v line that's on while cranking and IGN on?Black 89Turbo wrote: In line. on the signal wireBLOZ UP.com
Yes.
12v while ign on & cranking
Pin 24 going to white wire on cas w/ reistor in line
Grounds, ground
Green not used89' Turbo-R.I.P. (scrapped)
And the white wire is going to G/B?Black 89Turbo wrote: Yes.
Grounds, ground
Green not used
EDIT: I'm still not getting the picture here. Pin 24 should have a ~1k resistor connecting it to a +12v source. It shouldn't be "inline"; I'm not sure what you mean by that.BLOZ UP.com
