Megasquirt info
Black 89TurboSenior Member
- 495
rambis wrote: Why not go edis?89' Turbo-R.I.P. (scrapped)
- 495
BLOZ UP wrote: 60 degree signal, G/B - Green w/Black stripe, not G/O. It goes to pin 24, after being pulled up to 12v from 5v. That's the purpose of the resistor.
The G/W is the 360 degree signal, and is not currently used.
The other two are power and ground for the optical sensor itself.89' Turbo-R.I.P. (scrapped)
BLOZ UPSenior Member
- 2971
The TPS is easier. 3 wires, all can come from MS. MS provides the 5v reference, signal, and ground.
I can't remember the wire colors, but the ground should be obvious, and the FSM will let you know as well.
You need an automatic TPS though, the one with the 3 wire harness coming off of it. The switch portion of it is not used.BLOZ UP.com
- 495
BLOZ UP wrote: The TPS is easier. 3 wires, all can come from MS. MS provides the 5v reference, signal, and ground.
You need an automatic TPS though, the one with the 3 wire harness coming off of it. The switch portion of it is not used.89' Turbo-R.I.P. (scrapped)
- 2971
[quote]Black 89Turbo wrote:Originally posted by BLOZ UP:34y980d7The TPS is easier. 3 wires, all can come from MS. MS provides the 5v reference, signal, and ground.
The TPS should have ~6 wires total or 6 connections. 2-3 on the sensor itself and then a 3 wire harness coming out of it. The latter is what you need.BLOZ UP.com
- 495
It is not a auto TPS. Just 3 wires to the sensor itself. does not have the 3 wire harness for the automatic stuff. What is latter?
https://fund-solvaren.com.89' Turbo-R.I.P. (scrapped)
michaelpSenior Member
- 9384
[quote]BLOZ UP wrote: [quote=Black 89Turbo:2traphq1]Originally posted by BLOZ UP:2traphq1The TPS is easier. 3 wires, all can come from MS. MS provides the 5v reference, signal, and ground.
The TPS should have ~6 wires total or 6 connections. 2-3 on the sensor itself and then a 3 wire harness coming out of it. The latter is what you need.[/quote:2traphq1]
Only 85-89 automatic cars have the extra wire harness.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
- 2971
Black 89Turbo wrote: It is not an auto TPS. Just 3 wires to the sensor itself. does not have the 3 wire harness for the automatic stuff. What is latter?
Don't hook up to the black box, as it's just a switch. It will give you "undesired" results. You need that 3 wire harness coming out to hook up to.
Or just run with MAPdot enrichment.BLOZ UP.com
- 495
gotcha. i was wondering if the tps was a "switch" style 0 or 100% or 0, 1,2,3,4,5% ect… Thanks for clearing that up. i found some of your old maps and ill start with them. I have nothing to start by besides that.89' Turbo-R.I.P. (scrapped)
- 495
BLOZ UP-
Do you still have the writeup you did?89' Turbo-R.I.P. (scrapped)
slingoMember
- 63
Bump, this would be helpful for me as well, have an MS2/PCB3.57 running extra 3.1.1 soon to be in my 84t, if you guys could repost the original articles that would be amazing. -
- 495
it would be awesome. I tried to get diagrams but never could.89' Turbo-R.I.P. (scrapped)
- 495
What does *pin 36* run to with the stock coil? or is it not used?
- 2971
If you are using the MS coil driver, it connects to the coil.
Otherwise, it connects to the Nissan/Aftermarket coil driver.
I had good success with the Nissan coil driver (ignitor, I think the FSM calls it), since it is external and has it's own heat sink (at least on an 88t). I used 2.0ms as the dwell time, nothing else worked as well.BLOZ UP.com
- 495
BLOZ UP wrote: If you are using the MS coil driver, it connects to the coil.
I had good success with the Nissan coil driver (ignitor, I think the FSM calls it), since it is external and has it's own heat sink (at least on an 88t). I used 2.0ms as the dwell time, nothing else worked as well.89' Turbo-R.I.P. (scrapped)
