I could see heat soak as an issue depending on the material used and routing. But given my experience on my intake piping running only warm to the touch with the engine at normal op temps I have to wonder about the heat soak idea on intake piping overall. Obviously less heat is better but...
With an inter-cooler I would think that the relative temps would be the biggest concern. Here is my thinking on this one:
I have seen FEW turbo setups with an induction setup (filter) that isn't sucking in hot air. I still don't understand that. :?
Add an inter-cooler with the routing and SS pipes with urethane bends that works for you. (Welding them is cheaper and may look better if done well but it is more time consuming and it doesn't help the heat issue. :shock: )Worry more about intake temp than heat soak on the piping.
Turbo or NA- cold intake air ( or coldest possible intake air ) is the key to controlling the temp of the air that reaches the TB. Now we all know that there are other things that can be done to help reduce heat after the TB. Eliminate the "coolant" lines to the TB and plenum and....NEWS FLASH....Jason has a phenolic spacer that will make HUGE differences in the heat soak of the plenum.
Hmmm...now the question becomes what is more detrimental- heat from the radiator or the engine block radiating up through the upper plenum? :shock:
Now imagine that you are sucking in cool air with no "coolant" heating things up and you have an upper plenum that is cool to the touch at normal operating temps....Sounds good to me. But hey... it could all be just theory. 8)
