Refresh
This website z31performance.com/forum/z31-performance-upgrade-forums/engine-mechanical-aa/1253-true-or-false-timing-belt-q is currently offline. Cloudflare's Always Online™ shows a snapshot of this web page from the Internet Archive's Wayback Machine. To check for the live version, click Refresh.
TRUE or FALSE?? Timing belt Q!
  • TRUE or FALSE?? Timing belt Q!
    my valvrs are bent due to my timing belt snaping on the freeway. is this a proven fact?
    the only question is how many, and whether you need new pistons too
      What exactly are you asking? If your timing belt breaks will you 100% bend valves? No, mine stripped once and it ran fine after i changed it. I got lucky! Most of the time it will bend your valves though.
      KILL HADJI
        At freeway speeds if the belt breaks or goes slack due to a tensioner malfunction...True...you will have bent valves almost guaranteed.
        Performance costs money.
          Well my belt stripped on the freeway, the motor shut down. and stupid me before even looking to see what happened i tried starting the car. I was just wondering if i did damage because i have heard that the valves will bend if your belt snaps. so is it for sure, do i need to remove and rebuild or should i just throw a new belt on?
            You will be able to hear it if something has collided inside. I also tried starting it right after it shut off also. Also i was cruising at about 50mph.
            KILL HADJI
              Start with the cheapest thing first. Either way, you will need a new belt and tensioner. Put that on and see if that did it. Probably wont because if it just died at highway speeds you prolly killed your valves. If your valves are toast however you didnt waste any money from buying the tensioner and the belt because you need that anyways.
                SATAN wrote: Start with the cheapest thing first. Either way, you will need a new belt and tensioner. Put that on and see if that did it. Probably wont because if it just died at highway speeds you prolly killed your valves. If your valves are toast however you didnt waste any money from buying the tensioner and the belt because you need that anyways.
                Agreed, but even if it runs fine do a compression test.
                KILL HADJI
                  Hey thanks for the advice, i know what i have to do i just needed to hear it from someone else. and for you SATAN Thats gotta be 1 of the COOLEST z31 pics ive ever seen!!
                    Yeah, its cool. I fried a JE piston in that pic due to a plug that got to hot and exploded. Had to tear the whole engine down because of that. Note:make sure you run cold enough plugs with lots of power!
