NISMO heads for the VG30E/ET
a22770Senior Member- 207
Trying to avoid the beryllium. Kinda hate the idea of cancer causing substances. Looking at moldstar, might give them a call. -
Dr. Pepper PhD.Senior Member- 1301
So what is the final plan for these heads? Monster turbo engine? Or high compression methanol motor w/ nitrous?88SS - #300 - http://z31performance.com/showthread.php?18360 -
why not just use a respirator?a22770 wrote: Trying to avoid the beryllium. Kinda hate the idea of cancer causing substances. Looking at moldstar, might give them a call. -
ZFast88ZSenior Member- 1882
Let me know what you hear back from Moldstar.The bullshit stops, when the GREEN light drops.
acemanSenior Member- 1566
so much money for 300hpa22770 wrote: Plans for the motor are n/a. High revving drag setup.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
[quote]aceman wrote:I'd be he could do better than 300hp....L32 strokers do. :nanan?reOriginally posted by a22770Plans for the motor are n/a. High revving drag setup.so much money for 300hp- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
thats like buying a 100mm turbo and aiming for 300-400hpNearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
NissanEggSenior Member- 5220
And your point? These are not production car parts that fit your ideal of what "I would do with setup x or part y." So your argument is invalid.aceman wrote: thats like buying a 100mm turbo and aiming for 300-400hp
You're not the one buying the heads.
You're not the one modding the heads.
You're not the one trying something different.
You're not the one tyring to be helpful and experiment.
It's his money and time. Let him spend it as he sees fit.
I'm curious as to what these heads can do.
best seeds Canada.
[quote]NissanEgg wrote:Nobody is stopping anyone from doing anything, argument remains valid. We know what the heads do, as they are not new.Originally posted by acemanthats like buying a 100mm turbo and aiming for 300-400hpAnd your point? These are not production car parts that fit your ideal of what "I would do with setup x or part y." So your argument is invalid.
I'm curious as to what these heads can do.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
Your argument is not valid at all. Head work benefits both turbo and N/A cars.aceman wrote:
What's wrong with getting the most premium set of heads to achieve the best N/A numbers?
It's not even in the same ballpark as buying a 100mm turbo to make 300hp. That's stupidity + overkill.
If you want to make N/A numbers, you would need better flowing heads. And that's exactly what these seem to be.
So again, how is your argument valid? -
You can spend as much as you want NA and it will still make less usable power than a stock turbo motor with a stock fuel system. For that reason it makes no sense, there is no return on investment.
Since you have to build the exhaust system anyways you may as well use a properly sized turbo and get return on your time. The total price of the build goes up 10% and you get 90% more usable power.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
MADMIKESenior Member- 1533
True as that may be, he can always drop compression later and go turbo, and make stupid numbers.
As far as NA 300hp, that would be quite the feat. 100hp a liter is damn good. Could bottle feed, slap them on a 3.3 and go nuts.
Personally I would like to see you bore a vg33 out to 98mm and make the supposed vg38. I've seen rumors just never seen a real build.DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
exactly, nothing he's doing would "hurt" going turbo later, and it will be a fantastic experiment to see how far our lump of iron can go… much like the corvette guys squeezing everything out of their lumps
besides having a 300hp+ n/a that revs high, means a huge powerband, with the right gearing and final ratio, he could even have a very linear and predictable road race car that will keep up with anything made today -
Rebello builds 400hp L28s stroked and bored to 3.2s....theres no reason a high compression NA VG30/33 couldn't be badass.
This is mild:
http://www.youtube.com/watch?v=eO4Yhqo8E6I[/video]]- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
