NISMO heads for the VG30E/ET
a22770Senior Member- 207
Assembling right now what should make 300+ n/a with 85e heads. Already have a mild setup making 220 to the tires through a 30 mm single inlet restrictor and 9.8 to 1 compression.
Ran some math on the heads and measured some and should be achievable to make 400+ n/a with pistons speeds in the 4500 fpm range and intake valve in the 1.800 range. Gonna take some development though. -
You got dyno sheets? I'm interested in seeing that....a22770 wrote: Assembling right now what should make 300+ n/a with 85e heads. Already have a mild setup making 220 to the tires through a 30 mm single inlet restrictor and 9.8 to 1 compression.
Ran some math on the heads and measured some and should be achievable to make 400+ n/a with pistons speeds in the 4500 fpm range and intake valve in the 1.800 range. Gonna take some development though.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
RocklinMike300zxSenior Member- 276
That isn't a bad power and though. You plan on advancing timing for a better low end or retarding it to bring up your total hp at its peak? -
stuffertonSenior Member- 467
Any updates on this awesome-ness that's happening?
Build thread http://z31performance.com/showthread…-Paint-done-eh -
FlawleZSenior Member- 1971
And why only 9.8:1? I know we don't have the best options for pistons but on an NA build there's no reason not to shoot for 11:1+ standard pump gas. Also would be interesting to see what this would do on E85.a22770 wrote: Assembling right now what should make 300+ n/a with 85e heads. Already have a mild setup making 220 to the tires through a 30 mm single inlet restrictor and 9.8 to 1 compression.
Ran some math on the heads and measured some and should be achievable to make 400+ n/a with pistons speeds in the 4500 fpm range and intake valve in the 1.800 range. Gonna take some development though.545 RWHP & 540 RWTQOriginally posted by Andrew84zx
I didnt build the motor, pretty sure i would have had around 13 to 1.
Think he had some flat tops lying around and threw it together. Pretty mild cam too with 228 deg. at .050".
Nash heads are on hold till the spring. -
lapp90Junior Member- 3
bulding a big hp engine now. my heads are crakt so i need some new ones and i think these will do the job. if you just have them laing around you can sell them to me? and i can se what they can do whit the gtk1000 turbo
bad english of course im from norway
Twotone200488Member- 51
I'm pretty stoked to see what an n/a can do with these heads. I've never heard of the 3.8 out of a vg33, that sounds like that would be a interesting build. What pistons would you use? -
gen3buJunior Member- 25
[quote]FlawleZ wrote:contact russ, he has 12.5:1 ross pistons in his n/a. maybe he can post a dyno sheet too.Originally posted by a22770Assembling right now what should make 300+ n/a with 85e heads. Already have a mild setup making 220 to the tires through a 30 mm single inlet restrictor and 9.8 to 1 compression.
And why only 9.8:1? I know we don't have the best options for pistons but on an NA build there's no reason not to shoot for 11:1+ standard pump gas. Also would be interesting to see what this would do on E85. -
MADMIKESenior Member- 1533
Russ' Dyno sheet
DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale -
[quote]gen3bu wrote: [quote=FlawleZ]Its funny because a22770 made almost as much power and more torque with about the same curve as russ....with 9.8:1 CR not 12.5:1.Originally posted by a22770Assembling right now what should make 300+ n/a with 85e heads. Already have a mild setup making 220 to the tires through a 30 mm single inlet restrictor and 9.8 to 1 compression.
contact russ, he has 12.5:1 ross pistons in his n/a. maybe he can post a dyno sheet too.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Being a machinist has it's advantages I bet.DD:
86 Black Turbo 5spd
The Fallen:
Parting Currently:
Garage Sale
