electric water pump?
Chrisw_2003Senior Member- 2503
I was wondering if anyone uses one? I was talking to a few of the guys at my local autox and alot of them seemed to run them in there cars, being once you turn your car off the water flow stops. While with the electric pump they just flick the switch and the water keeps circulating helping the car cool down faster between laps. -
New 2 ZSenior Member- 1219
i was looking at the L series pumps only one bolt will fit. no one makes it for our cars, i'd love one though. maybe look into the SR20 pumps?Chrisw_2003 wrote: I was wondering if anyone uses one? I was talking to a few of the guys at my local autox and alot of them seemed to run them in there cars, being once you turn your car off the water flow stops. While with the electric pump they just flick the switch and the water keeps circulating helping the car cool down faster between laps.
comrade_charlieBanned- 355
[quote]New 2 Z wrote:i was looking at the L series pumps only one bolt will fit. no one makes it for our cars, i'd love one though. maybe look into the SR20 pumps?[/quote:3468f4nt]Originally posted by Chrisw_2003:3468f4ntI was wondering if anyone uses one? I was talking to a few of the guys at my local autox and alot of them seemed to run them in there cars, being once you turn your car off the water flow stops. While with the electric pump they just flick the switch and the water keeps circulating helping the car cool down faster between laps.
l28 swap time LOL -
[quote]comrade_charlie wrote: [quote=New 2 Z:29gze5ej]i was looking at the L series pumps only one bolt will fit. no one makes it for our cars, i'd love one though. maybe look into the SR20 pumps?[/quote:29gze5ej]Originally posted by Chrisw_2003:29gze5ejI was wondering if anyone uses one? I was talking to a few of the guys at my local autox and alot of them seemed to run them in there cars, being once you turn your car off the water flow stops. While with the electric pump they just flick the switch and the water keeps circulating helping the car cool down faster between laps.
l28 swap time LOL[/quote:29gze5ej]
it could work… the L series is just about 2 inchs taller then a RB26, was thinking about it but it's too much work. not to mention they have the worst head flow then any of the Z cars. ever produced.
So are you guys talking about having a pump attached to the waterpump via a pulley, or directly attached to the waterpump.
Or even more serious, a remanufactured pump that has been turned into an electric one?
Either way, have you guys heard the whine they make? SOOOOO annoying for a street car. -
no. just a electric pump that that pumps water throughout the cooling system.
https://cosmeprogramme.org/. -
DeleriousZSenior Member- 6874
Like something you'd stick inline with the rad hose? How would you get the thermostat to stay open once the coolant got past that point?
1990 jetta vr6'd -
BLOZ UPSenior Member- 2971
Genius.Careless wrote: a pump attached to the waterpump via a pulleyBLOZ UP.com
nutsaqSenior Member- 208
acemanSenior Member- 1566
just make a bracket for a 12v motor and pully, and run the water pump by a 12v motor. im sure you could even get trick with it, and put speed control on it.Nearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
OK85ZXSenior Member- 1690
[quote]BLOZ UP wrote:lmao. the wording just made it sound funny for this situation :POriginally posted by Carelessa pump attached to the waterpump via a pulley
Genius.1985 NA2T(now RB) * 1988 SS x2 * 1984 AE x3 * 2006 350Z
MachZSenior Member- 386
Last I checked the bolt pattern is the same. I'll double check tonight but I'm pretty sure I bolted the DE pump to my 30E.nutsaq wrote: how much different is the VG30DE? -
[quote]BLOZ UP wrote:I meant a motor attached to the waterpump. sorry.Originally posted by Carelessa pump attached to the waterpump via a pulley
Genius. -
you would essentially run no thermostat, and just have it circulate at different speeds, is my guess!DeleriousZ wrote: Like something you'd stick inline with the rad hose? How would you get the thermostat to stay open once the coolant got past that point? -
Matt89Senior Member- 2380
Yeah i an 99% sure a DE pump shares the same design and bolt pattern as ours. :-)Bolt on, fast, z31. You can only pick two.
