skeeterSenior Member- 130
Re: S13/S14/S15 Subframe Conversion Kit GROUP BUY
The s14 diff cover has a 2 bolt mount setup, while the s13 has a 4 bolt mount setup. This is why you have to use the s13 diff cover when you swap a s14, J30, or q45 vlsd into a s13 sub-frame.RXGhost wrote: is there any reason this would not work for the s-13 sub-frame and diff?
http://www.enjukuracing.com/greddy-diff … -7790.html -
OK85ZXSenior Member- 1690
There is probably a reason when a seller makes it a point to list it as S14 ONLY, limiting their market. A minute or two of google image searching shows the differences well
RXGhostSenior Member- 510
LOL I guess I should have looked for the diff cover I was just looking at the sub-frames to compare
LOL and on top of that looks like the sub-frame and diff I pulled out of a 1989 only has two bolts for the diff cover lol now this makes me wonder what I have sitting on my floor1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
Side-note: someone needs to see if the increased capacity diff cover actually clears the gas tank on the Z31, as I imagine it may stick out a bit too much and may make contact. Even 1/4 inch of space on a hard launch might be cutting it close due to torsion, but I've never been under a car to witness how much it twists at the mounts during a launch (who has?)- especially with solid mount bushings.
but judging from this image below, it looks like there is plenty of room:
acemanSenior Member- 1566
[quote=Careless]Side-note: someone needs to see if the increased capacity diff cover actually clears the gas tank on the Z31, as I imagine it may stick out a bit too much and may make contact. Even 1/4 inch of space on a hard launch might be cutting it close due to torsion, but I've never been under a car to witness how much it twists at the mounts during a launch (who has?)- especially with solid mount bushings.
nothing a hammer cant fixNearly all men can stand adversity, but if you want to test a mans character make him a moderator. -
ButterSenior Member- 1519
I have the Q45 cover, which is basically the same thing, and it clears just fine.sigpic -
Rambo69Member- 92
Any word on when t his kit will be available for individual sales....or the next group buy?sigpic
NWN Moderator
FertilePower on XboxLive -
MrFishHatSenior Member- 505
Im sure a few people who are buying it only plan on reselling for a higher price as soon as they get it.Rambo69 wrote: Any word on when t his kit will be available for individual sales....or the next group buy? -
ShamWowSenior Member- 1905
Update.
Manufacturing is well underway. I have 3 suppliers for the project, so getting everyone on the same time schedule has been interesting. Do I have finished/welded pictures for you? No.. Have I test fit it on my car? YES. Its magnificent.
Yesterday, MANY of these were made. They all look this good too.
"produce first.talk second." -
Re: S13/S14/S15 Subframe Conversion Kit GROUP BUY-Lathe Candy
Mike G for president (and prime minister, at the saaaaaame tiiiiiiiime) -
nismopuAdministrator- 2221
Yous good wit da lathe dewd!"Its the s12's sexy over weight step daughter, the z31" -
BenedictSenior Member- 915
Awesome.
I wrap my paper weights in glitter. -
DudeZXSenior Member- 623
That is awesome mike thanks again for this kit1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
Do you have the price finalized yet?"Its the s12's sexy over weight step daughter, the z31"
