ShamWowSenior Member- 1905
Re: S13/S14/S15 Subframe Conversion Kit GROUP BUY-Lathe Candy
^ Still awaiting quote from one of the suppliers.."produce first.talk second." -
XDRIFTKIDXJunior Member- 19
do u have a musement of how long the drive shaft need to be or can you use the stock z driveshaft? -
it really depends on what kind of car you have and the shaft yolk and differential flange are different for certain trims/years as well, so you would have to have a custom longer driveshaft made that mike has not supplied measurements for.XDRIFTKIDX wrote: do u have a musement of how long the drive shaft need to be or can you use the stock z driveshaft?
I imagine the only one you will see when they start rolling out are the measurements mike had for his own setup- which some will mimic or he can probably refer to who made it for him.
The other sizes/types/suppliers will eventually surface as more people tackle the install successfully. -
ButterSenior Member- 1519
From the multilink swap thread WHICH YOU SHOULD READ IN IT'S ENTIRETY BEFORE GOING THROUGH WITH THE SWAP....
Here are the parts I've used on driveshafts for the subframe swap. These are part#'s for Powertrain Industries https://www.powertrainindustries.com/catalogs.htm . It should be enough info to steer your local ds shop in the right direction so they can build you a shaft. Here it go.
Slip Yokes
30A: Part#3103-30
71C: Part#3103-24
T-5: Part#3103-26
U-joint
1310 Spicer non-greaseable
Pinion Flange
S14: Part#3102-21
Pretty sure all S-chassis are the same. Compare the measurements of this part and measurements on your diff pinion flange to make sure if it will fit.
PART NUMBER 3102-21
PILOT DIA. 1.967
BOLT CIRCLE DIA. 3.200
BOLT HOLE DIA. .395
FACE TO C/L 1.772
Shaft Length
2-seater: 760mm (measured between C/L of U-joints)
2+2: This should be the above + the difference in the stockers?
sigpic -
Mike,
Any updates? I'm in no hurry or anything, i'm just curious as to how things are going. Again thanks for all the effort.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
Update.
Will have update put together soon. Production wraps up today and (assuming all is well) it looks like kits could be available as early as next week."produce first.talk second." -
nismopuAdministrator- 2221
All this before Branson? You da man Mike! Any chance you would be delivering kits to Branson?Mike_GruiZinga wrote: Update.
Will have update put together soon. Production wraps up today and (assuming all is well) it looks like kits could be available as early as next week."Its the s12's sexy over weight step daughter, the z31" -
RXGhostSenior Member- 510
SWEET !
I was starting to get antsy with all the cutting and welding I have been doing myself this kit is going to be the icing on the cake1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
adamvann3Senior Member- 4160
[quote]nismopu wrote:Thinking the same thing.Originally posted by Mike_GruiZingaUpdate.
Will have update put together soon. Production wraps up today and (assuming all is well) it looks like kits could be available as early as next week.All this before Branson? You da man Mike! Any chance you would be delivering kits to Branson?86na - BlueZ
85t - Mr Tickles -
stprasinzSenior Member- 300
badboyz31Senior Member- 2403
I'm so ready for this, I need it in my life!1uz Swapped, lowered, flaked out '86 z31
UPDATE:
Dave at Touge Factory would like to further support the development of the Z31 chassis. They have offered to sell us their aluminum subframe bushings at the discounted price of $110 if 10 people buy bushings. Normal Price is $149 on these bushings.
If you would like Touge Factory Aluminum Subframe Bushings to go with your Subframe conversion kit, please PM me here. The total will be due with the remainder of the subframe conversion kit payment. The list on page 1 will be updated with those who would like bushings.
This price is good for the standard bushings (adapting S13 subframe) as well as the offset (adapting S14/S15). Please specify which with your payment.
The subframe conversion kit is 90% done. I have not yet received the CNC plasma cut "box in" pieces for the front extensions. Please be patient, they are trying to get them finished this week.
-Mike"produce first.talk second." -
DudeZXSenior Member- 623
Buy some bushings folks. You're gonna need them sooner or later, might as well take advantage of the low price…Tinker Toy Equipped
skeeterSenior Member- 130
Great deal on the bushing set. Too bad I was impatient and bought my set from them a month ago. I could have saved some money. In my opinion, theyâre worth the $149 I paid and I think they are definitely worth the $110 thatâs being offered now. Jump on this deal people and help support a great company that supports the z31 community.
