Brake Upgrade Thread
adamvann3Senior Member- 4160
Found this info on another forum, thought it would serve well here as well
Front Disc-------Diameter---Height---Thickness--Min. Thick.--Center Hole
S14---------------10.12-----1.93------0.87--------0.79----------2.68
300ZX TT---------11.02-----2.13------1.18--------1.1-----------2.68
350Z Brembo------12.76-----1.93------1.18--------1.1-----------2.68
370Z Brembo------13.96-----1.95------1.26--------1.18----------2.68
94+ 3KGT VR4-----12.36-----1.79------1.18--------1.12----------2.72
Mustang Cobra----12.99-----1.71------1.1---------1.04-----------2.8
Lancer EVO IX-----12.6------1.71------1.26--------1.17----------2.72
Lancer EVO X-----13.78-----1.73------1.26---------1.18---------2.72
R32 T : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T (early) : 280mm x 26mm (single pot sumitomo caliper)
R32 GTS-T type m : 280mm x 30mm (4 pot sumitomo caliper)
R32 GTR : 296mm x 32mm (4 pot sumitomo caliper)
R32 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R33 GTS-25 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-4 : 280mm x 26mm (single pot sumitomo caliper)
R33 GTS-25T : 296mm x 30mm (4 pot sumitomo caliper)
R33 GTR : 324mm x 32mm (4 pot brembo caliper)
R33 GTR VSPEC : 324mm x 30mm (4 pot brembo caliper)
R34 GT : 296mm x 30mm (4 pot sumitomo caliper)
R34 GTT : 310mm x 30mm (4 pot sumitomo caliper)
R34 GTR : 324mm x 32mm (4 pot brembo caliper)
Z33 NA : 324mm x 32mm (4 pot brembo caliper)
Z32 NA : 280mm x 26mm (4 pot sumitomo caliper)
Z32 TT : 280mm x 30mm (4 pot ali sumitomo caliper)
S14, S15 : 280mm x 30mm (4 pot sumitomo caliper)86na - BlueZ
85t - Mr Tickles -
BremsenSenior Member- 242
I'm looking to do a front and rear Z32 swap on an 88NA. Setting up for track use and need better race pad availability and some unsprung weight reduction. I've read (can't remember if it was this thread) that the J30 hubs might work as a substitute for the hard to find turbo hubs. Has anyone been able to confirm/deny that they will work?________________
1987 Chumpcar -
z31manJunior Member- 6
I've read a lot of what you guys have posted and I'm a noob when it comes to car term so im going to ask you guys for your opinion on the most efficient/less cost expensive set up for my stock 88t. Not planning on tracking anytime soon just feel like upgrading the old brake set up with some ss lines. I was thinking maybe z32tt front swap considering it seems to be the easiest just trimming.. As for the rear I don't quite understand what you guys are posting and again sorry if I do not understand the basic things you guys are putting out there. -
If you dont plan on tracking your car and just use to 'cruise' around in just use a really good pad and SS lines. The twin piston calipers are more than capable on the z31z31man wrote: I've read a lot of what you guys have posted and I'm a noob when it comes to car term so im going to ask you guys for your opinion on the most efficient/less cost expensive set up for my stock 88t. Not planning on tracking anytime soon just feel like upgrading the old brake set up with some ss lines. I was thinking maybe z32tt front swap considering it seems to be the easiest just trimming.. As for the rear I don't quite understand what you guys are posting and again sorry if I do not understand the basic things you guys are putting out there.86na - BlueZ
85t - Mr Tickles -
I drive an auto just want feel like upgrading the brakes just because its about that time I might as well upgrade them too. Correct me if I'm wrong the z32tt caliper is direct bolt on and in order to make the rotor plus caliper sit correctly I must either shimmy or remove my dust shield. Then after that is there anything else I have too do? Do I just remove my brake set up and just look at everything I'm removing and reinstalling it to the z32 parts? Is it that simple or am I missing something. -
Shim and trim the dust shield. You will either need conversion lines or take your z32 calipers apart to take out the bushing to use your z31 linesz31man wrote: I drive an auto just want feel like upgrading the brakes just because its about that time I might as well upgrade them too. Correct me if I'm wrong the z32tt caliper is direct bolt on and in order to make the rotor plus caliper sit correctly I must either shimmy or remove my dust shield. Then after that is there anything else I have too do? Do I just remove my brake set up and just look at everything I'm removing and reinstalling it to the z32 parts? Is it that simple or am I missing something.86na - BlueZ
85t - Mr Tickles -
[quote]adamvann3 wrote:so in other words I buy z32 rotors find a use z32 caliper and buy this ss brake line conversion ? http://www.pdm-racing.com/products/brakeslines.htmlOriginally posted by z31manI drive an auto just want feel like upgrading the brakes just because its about that time I might as well upgrade them too. Correct me if I'm wrong the z32tt caliper is direct bolt on and in order to make the rotor plus caliper sit correctly I must either shimmy or remove my dust shield. Then after that is there anything else I have too do? Do I just remove my brake set up and just look at everything I'm removing and reinstalling it to the z32 parts? Is it that simple or am I missing something.
Shim and trim the dust shield. You will either need conversion lines or take your z32 calipers apart to take out the bushing to use your z31 lines -
86na - BlueZ
85t - Mr Tickles -
jamesSenior Member- 978
Z32 4 Pots and 280x30mm rotors
USING 85 Turbo Hubs
Full write up here & works with factory wheels
viewtopic.php?f=24&t=26792
feminized indica seeds.85 Turbo Slick Top
Matt89Senior Member- 2380
I have an extra set of 88t front hubs. PM if interested.Bremsen wrote: I'm looking to do a front and rear Z32 swap on an 88NA. Setting up for track use and need better race pad availability and some unsprung weight reduction. I've read (can't remember if it was this thread) that the J30 hubs might work as a substitute for the hard to find turbo hubs. Has anyone been able to confirm/deny that they will work?Bolt on, fast, z31. You can only pick two.
NA Hubs can be made to work easily enough if you can't get a set of 88 Turbo hubs, I have no idea about J30 hubs but Russ84NA is using 84 NA hubs with slip on rotors and I am using Slip on rotors with 85T front hubs. See the link I posted bottom of page 4Bremsen wrote: I'm looking to do a front and rear Z32 swap on an 88NA. Setting up for track use and need better race pad availability and some unsprung weight reduction. I've read (can't remember if it was this thread) that the J30 hubs might work as a substitute for the hard to find turbo hubs. Has anyone been able to confirm/deny that they will work?85 Turbo Slick Top
Ended up buying a whole parts car that has the turbo hubs. Thanks for the offer though, matt.
James, yeh I saw Russ' thread after I made the post and was looking at getting them machined.
I'm using 88T hubs and discs with 26mm Z32 calipers. From my research this should be a straight bolt up with no shims required. Decided just to keep the rear calipers, not worth the $$ to swap.________________
1987 Chumpcar -
shims and such are only required for converting early style hubs, you are correct everything bolts up. If in doubt see Jasons writeup on redz31.net85 Turbo Slick Top
DMANNSenior Member- 544
Don't know if this helps but…I did the S13 swap, and Z32 alum. knuckles. with Z32 calipers in the rear.
Used z32 rotors and everything worked fine.
Since I had almost new Z31 brake flex lines I reused them on the Z32 calipers.
Used this for about 8 months now with no troubles!88na2T-s13,q45 swap 12.6@110mph
87T 2+2 auto,stock -
Wilwood Forged Superlites
Piston Diameter: 1.620 in x4
Rotor Thickness:1.250 in
Pads: 150-8854K
Lines: Wilwood s13
Rotors: 350z Track Rotors (12.76")
Custom caliper spacer
Only compatible with late turbo hubs (or modified other)
Needs z32 BMC or equivalent to gain firm pedal86na - BlueZ
85t - Mr Tickles
