Brake Upgrade Thread
  • Taris Blue
    Taris Blue
    • 537
    #76
    Maybe it's an optical illusion, but it looks like there is pad overhang with the Wilwoods…confirm/deny?
    2006 Scion tC (Wife Whip)
  • RXGhost
    RXGhost
    • 510
    #77
    Looking at his other pictures I see the same
    were you able to correct that Adam?
    1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
    1998 Mazda B-2500, And a lot of bikes
  • adamvann3
    adamvann3
    • 4160
    #78
    There is zero pad overhang. That was the only picture I have currently and was during fitment. The caliper isnt bolted tight and the rotor wasnt pressed up against the hub, I was busy trying to center everything to figure out shims. With everything tight, the pad is fully seated.
    In the future I plan on replacing the rotor with a 2 piece using a larger diameter hat. You can see the ring where the pad isnt hitting the bottom portion of the rotor.
    86na - BlueZ
    85t - Mr Tickles
  • RXGhost
    RXGhost
    • 510
    #79
    sweet that had me worried for a little because that is my next mod
  • james
    james
    • 978
    #80
    There is loads of options for a front brake Upgrade, so now am investigating fitting 88 Turbo Rear Calipers on an 84-86 Early style control arms.
    I can confirm that the 88 caliper bolts up successfully to an 85T rear control arm.
    When dummy fitting the SOLID rotor With the Vented Caliper the offset or height of the rotor seems to be too large
    listed as 47mm for an 85 turbo rear rotor - & 57mm for an 88 turbo rear rotor.
    This means using an 88turbo rear rotor is out of the question, and finding a large diameter vented rotor with a low offset seemed highly unlikely until i found this Jaguar or a 2000 S Type ( X200 series )
    The Jag Rotor is listed as 288 OD with a height of 33mm and a Center bore of 64.5, while 5 stud i believe it is 108 or 110 PCD
    I believe that if the Center-bore was opened up to 68mm and this rotor was re drilled as 5x114 that this would be suitable for use on 84-85 Rear control arms using 88 Turbo Vented Rear calipers.
    This would potentially require spacers to bring the caliper away from its mounting bracket by a few mm.
    [attachment=0:vh1wy0dv]jag rotor.png[/attachment:vh1wy0dv]
    I put this forward as an option to those who do not have aces to late style 88 rear control arms.
    I am In New Zealand and the cost of shipping would be prohibitive, I estimate Machining time to be approx 1hr or $60 on top of the cost of Jaguar Rotors
    Now my Question's
    Has anybody done anything simialr to save my time and dollars from inventing a new method ?
    Can Anybody else Find a better Option for a rotor ? Keeping in mind the total height needs to be lower than 47mm to stop the rotor hitting the caliper.
    if not would Users of Z3P make use of a full writeup to fit a vented setup on a 84-85 car ? If nobody is interested in doing this conversion it is a waste of time to do a detailed write up.
    an example of my other writeup can be found here viewtopic.php?f=24&t=26792
    EDIT >
    Been out to do some measuring
    OD of Rear Hub is 154.8 - 155mm
    you zoom in you can read the measurement , so that definitely fit inside the Jag Quoted measurement of 159mm
    Measuring Between the Pad Carrier i get 24mm
    Using a straight edge the face of the Hub to the Edge of the pad Carrier is 43mm
    43m ( hub to pad carrier ) minus 12.1 leaves me 31mm from the face of the hub to the center line of where the rotor needs to be.
    By looking at the Jag Drawing the inside of the rotor hat Minus half the thickness of the rotor leaves 15.5 ( face of hub to center line of rotor)
    So by those measurements this should completely work providing I use a 14.5mm Spacer
    85 Turbo Slick Top
  • NissanEgg
    NissanEgg
    • 5220
    #81
    What would be nice is for someone to make the rear Z32 calipers work on the Z31 rear control arm. I know the problem is the parking brake function, which can be remedied with a Wilwood line lock setup.
    mostbet mostbet mostbet.
  • james
    james
    • 978
    #82
    I think companies like Will wood make dedicated parking brake calipers
    somewhat simialr to these pictures
    http://www.panteraperformance.com/Photo … stems.html
    85 Turbo Slick Top
  • RXGhost
    RXGhost
    • 510
    #83
    I know that company they make some pretty cool kit cars for that pantera
  • james
    james
    • 978
    #84
    RXGhost wrote: I know that company they make some pretty cool kit cars for that pantera
    Probably tons more expensive than a line lock & leaving your car in gear
    Anyway, i have Ordered some Jag rotors so hopefully by next week i can put up some pictures of fitment and spacers ect.
    85 Turbo Slick Top
  • james
    james
    • 978
    #85
    Ok so Here is a Mock up consisting of the follow
    Jaguar S Type X200 Model series Rear Rotors 288mm x 20mm
    Longer Bolts
    Spacer for the caliper
    So Vented rear brakes on an 85 Turbo is now possible, Vented Rear brakes on an 85NA will require a completely different setup. I am in discussions with Russ84NA about how we can utilize 88 calipers on an 84- 85NA
    Full Write For installation on an 85 Turbo will be made in the next 2-4 Days
    85 Turbo Slick Top
  • LSXZ31
    LSXZ31
    Junior Member
    • 25
    #86
    Hey guys I am kind of new to the z31 scene. What is the cheapest upgrade for an '87 na? Should I machine down the hubs and get turbo rotors and longer studs? Do I have to run the turbo calipers?
  • RXGhost
    RXGhost
    • 510
    #87
    This is cool stuff for the rear if I wasn't swapping to -13 rear i would be jumping right on this great info james
  • adamvann3
    adamvann3
    • 4160
    #88
    adamvann3 wrote: Wilwood Forged Superlites
    Needs z32 BMC or equivalent to gain firm pedal
    After about 1k miles, this weekend the brake pedal became very firm. Before with the stock z31 BMC I would have to put my pedal to the floor in order to get them to lock up. Now it feels the same as running z32tt calipers + z31 BMC. Must have been some trapped air in the lines that worked itself back to the BMC.
    I am very pleased to have pedal feel back in the car. The z31 bmc impresses me with its capabilities.
    86na - BlueZ
    85t - Mr Tickles
  • Rick88ss
    Rick88ss
    • 2433
    #89
    Piston Diameter: 1.620 in x4
    Rotor Thickness:1.250 in
    Pads: 150-8854K
    Lines: Wilwood s13
    Rotors: 350z Track Rotors (12.76")
    Custom caliper spacer
    Only compatible with late turbo hubs (or modified other)
    Nice. How much did this setup cost?
    If I already have SS Z32 caliper lines can I use them?
    Shiro #443
  • Rick88ss
    Rick88ss
    • 2433
    #90
    This kit looks pretty good for $300 if you're using Z32 calipers.
    Thoughts?
    http://www.z1motorsports.com/240sx/prod … cts_id=141
    Shiro #443
