Transmission weights
I searched around a bit, but didn't find anything regarding the weight of the 3 z31 transmissions (T-5, 71c, 30a).
Does anybody know which of the 3 is the lightest and by how much? -
amrebootBanned- 9875
I can weigh the 30a for you when I get home.
But I am sure the 71c is the lightest, then the 90a, then the 30a. -
That would be awesome, thanks! I was guessing the same thing if weight scaled with how much power it is "supposed" to hold, but I guess it depends on a lot of things.Originally posted by amreboot View PostI can weigh the 30a for you when I get home.
I am just theorycrafting if I can shave weight by using scca update/backdate allowances. -
Alex is correct, but the difference isn't a lot, will you really notice 15lbs in the middle of the car? -
T5 (90A) is the lightest. Then 71C. Then 30A.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Ah, I guess I was hoping that it'd be a big difference.Originally posted by G-E View PostAlex is correct, but the difference isn't a lot, will you really notice 15lbs in the middle of the car?
Thanks! Any idea by how much?Originally posted by michaelp View PostT5 (90A) is the lightest. Then 71C. Then 30A. -
Axel kainModerator- 1221
I'll try to remember to throw my spare T-5 on a scale some time! haha.Damn dirty angels....these cars!
sigpic -
Well I'll be damned, just found the info in an old thread:
http://z31performance.com/showthread…ission-weights
Guess I'll keep the 71C then. -
I'd wonder about the Z32's 30A, considering it's a bit shorter…Damn dirty angels....these cars!
sigpic
