SATANSenior Member- 6782
I'm glad that the introduction of China turbo chargers (that appear to be doing the same job of the old turbo chargers), has come about. This is now FORCING American companies to get off of their asses to actually start to improve their designs and making better products.Careless wrote: Batmowheel, available for he351 and hx40!
http://www.cumminsperformanceparts.com/ … aishe.html85 Z31 6.0 LSX turbo 766whp/792wtq
For holset guys looking for a smaller turbine housing than what's available (12cm is .89 A/R), you can go this route, which is close to the BEP .70 housing which does not share a T3 flange that we utilize on our OEM manifolds:
http://www.ebay.com/itm/Holset-HX35-Tur … 696wt_1396 -
nismopuAdministrator- 2221
I just picked up an hx40 for cheaps, I may have to order this!Careless wrote: For holset guys looking for a smaller turbine housing than what's available (12cm is .89 A/R), you can go this route, which is close to the BEP .70 housing which does not share a T3 flange that we utilize on our OEM manifolds:
http://www.ebay.com/itm/Holset-HX35-Tur … 696wt_1396"Its the s12's sexy over weight step daughter, the z31" -
imho, it's not worth the extra money considering the idea of holsets is to get them cheap. I would only do so if it needed a rebuild!
EDIT: woops, though you quoted the batmowheel. Nevermind. Def worth! -
http://www.dsmtuners.com/forums/turbo-s … -pics.html Probably been posted here and it seems the guy has dropped the ball on the project but its a neat physical comparo."Its the s12's sexy over weight step daughter, the z31" -
cdiver666Senior Member- 181
Bought a Holset recently, and received it today. Thought I'd show a comparison picture since the one earlier in this thread no longer exists:
It is a HX35W.
Build thread: viewtopic.php?f=13&t=25322Originally posted by SATANI accept that challenge. I have seen "gods wrath"… I'm not impressed.Originally posted by Twisted`ZAll the violence and destruction of God's wrath is saved for those who oppose him -
This car is in Ontario somewhere.
[youtube:22q2yx13]y_ImDsveHpE[/youtube:22q2yx13]
Aside from the HX40s larger turbine, and the obvious difference in RB25 vs. VG33, My engine is equally modified, or will be. So it could be a good comparison once I put the 635cc's on there.R33 Nissan Skyline GTS-t
RB25DET (Internally stock)
GReddy Style Intake Plenum
Q45 Throttlebody
HDI Front Mount Intercooler
S-TEC Stainless Topmount Manifold
Turbosmart 60mm Wastegate
Holset HX40 Turbo @ 19.5 PSI
4" DP / 4" MP / 4" Exhaust to HKS Carbon Ti
HKS Boost Controller
APEXi RB26DETT PowerFC D-Jetro
Ironman Clutch and Flywheel
Bee-R Rev Limiter
Bosch 044 Fuel Pump
RC 720cc Injectors
Sard Fuel Pressure Regulator
STRi DSD 60mm gauges
HICAS Delete
Sunoco 94 oct
492 rwhp 364? lbft 20psi tuned
I'd say 400whp-450whp from the Careless Holset hybrid doohicky at 20 psi is not going to be hard to come by. -
Talked with Tim @ Tim's Turbos:
He has given me the following information:
Stock Holset 12cm^2 is close to .78 - .80 A/R
HE351 has an HX40 comp wheel and a turbine wheel that is smaller than an HX35 wheel and in a smaller 9cm^2 housing. Essentially an HX40/35 hybrid, but smaller on the hotside.
Seems like a knowledgeable fellow, and perhaps anyone looking for Holset turbos or upgrades can msg him for some info/stock. -
This might be redundant but here are some repair manuals on PDF
http://www.turbomaster.info/eng/turbos/ … =HX#holsetCha iro
these PDF's can also be opened in illustrator to "use" the vector images of the turbos and components too :-)Augustus Maximus wrote: This might be redundant but here are some repair manuals on PDF
http://www.turbomaster.info/eng/turbos/ … =HX#holset -
88sinZSenior Member- 2019
Nice find!
:lecture -
Holset HX52 in a boat… on a what?!
[youtube:2wguw01o]p1LCQhqobM0[/youtube:2wguw01o]
bawwwwwse 8) -
shromySenior Member- 2189
[youtube:2gyji89v]k8F3UE9qFsg[/youtube:2gyji89v]Hmmm, Whats next?
84ZXT -
Rb swap on a boat say whaaaaaaaCareless wrote: Holset HX52 in a boat… on a what?!
[youtube:2yh38v1p]p1LCQhqobM0[/youtube:2yh38v1p]
bawwwwwse 8)Hmmm, Whats next?
84ZXT
