Re: S13/S14/S15 Subframe Conversion Kit GB-Packaging and Pics
So TF is shipping out the bushings separately when ordered?Mike_GruiZinga wrote: Packaging came in finally, started assembly line with 2 other guys packaging this stuff up. I think the packaging is pretty efficient, and I sprayed all the steel down with anti-corrosion oil. -
ShamWowSenior Member- 1905
Yes stance bushings drop ship from Touge factory in Chicago. Can have stance multilink arms shipped at same time to save on shipping.
^will call Tf to get multilink pricing and update here"produce first.talk second." -
RXGhostSenior Member- 510
Heck yeah need prices on the arms
Hey mike do you think we need adjustable lower arms? i know stance doesn't make them
Powered by Fund Solvaren.1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
84Zed31Senior Member- 707
Please don't give up my kit
, i could have the rest of the money by next week. I'm short on cash right now.
"Let's play Battleship! There's enough Z's for that.."
My thread thingy: http://z31performance.com/showthread…ep-Zed-84Zed31 -
GreasedmonkeySenior Member- 516
Im ready to take anyones spot that cant pay. -
tfdaveMember- 98
[quote]Careless wrote:Yes, Once Mike gives us the final order, we will ship directly from here.Originally posted by Mike_GruiZingaPackaging came in finally, started assembly line with 2 other guys packaging this stuff up. I think the packaging is pretty efficient, and I sprayed all the steel down with anti-corrosion oil.
So TF is shipping out the bushings separately when ordered? -
tfdaveMember- 98
I can get you Megan Lower arms http://www.meganracing.com/product_deta … 9&catid=26RXGhost wrote: Heck yeah need prices on the arms
$400 shipped
Thanks
-David -
$400 shipped
Thanks
-David1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
Touge Factory is again giving us a deal on their parts. Anyone who buys the subframe swap kit is eligible for special group buy pricing… Check http://www.stance-usa.com/sus/ for more information on STANCE's multi-link components. They use quality Aurora teflon lined heims. They are professionally TIG welded. This is the setup I decided on for my personal car; the quality is excellent.
Pricing on Multi-link from STANCE (including shipping to USA):
Stance Rear upper control arm (S13/S14 same) -$230 (MSRP $280)
Stance Rear Toe arm (Must specify S13 or S14) - $200 (MSRP $240)
Stance Rear Traction arm (S13/S14 same) - $190 (MSRP $230)
Send payment for links to Mike_Gruizinga@yahoo.com The links will drop ship to your address and if you ordered STANCE bushings they will likely ship together."produce first.talk second." -
This kit just keeps getting better and better and the boys at Stance are really taking care of us, I really hope everyone is supporting them the same as I am
nismopuAdministrator- 2221
You can't build these components for these prices, lol!"Its the s12's sexy over weight step daughter, the z31" -
tfdaveMember- 98
[quote]RXGhost wrote:RXGhost - Yes, Please contact me directly. david(at)tougefactory(dot)com or 847-290-1531Originally posted by tfdaveI can get you Megan Lower arms http://www.meganracing.com/product_deta … 9&catid=26
$400 shipped
Thanks
-DavidIs that something you just want us to contact you directly for? -
tfdaveMember- 98
Want to add some more info on Stance links.
The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. The Stance links use Aurora's strongest billet 3 piece rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability. Our rod ends offer a high misalignment angle for extreme performance.
The Aurora Rod ends we use have radial static load of 32223 N, which equates to 7244 lbs-force. It's a 3-piece design with hardened steel. It also has 52degrees of misalignment angle, specifically for automotive use. If you were to buy these bearings from Aurora, it'll cost you $65/ea, just to give you an idea.
-David -
You have to pay for quality! The PTFE lining keeps things nice and quiet as well, where as the chinese high angle ones don't use lined bearings at all causing slop/noise.tfdave wrote: Want to add some more info on Stance links.
-David
DudeZXSenior Member- 623
I'm going to hang myself by my feet and see if enough change comes out of my pockets to get in on the multi-link group buy…Tinker Toy Equipped
