Brakes working too good…
  • boosted300
    boosted300
    • 195
    #16
    Originally posted by jaqattack02 View Post
    My plan is to upgrade both my rear calipers and rear pad compound. I just haven't actually gotten around to doing that. Need to swap my rear control arms first, along with getting the M30 ebrake drums installed.
    On a side note, for those that have seen the suspension Arizona Z makes for S30's…he's actually finalizing a similar setup for Z31's. Apparently it eliminates the crossmember and swing arms and utilizes a strut …can't wait to see that. Its gonna be interesting to see something that beautiful underneath a Z31.
  • boosted300
    boosted300
    • 195
    #17
    Originally posted by G-E
    The easiest/free upgrade you can try is shimming the rear bias spring in the master cylinder until it binds, it can be a pain to do…
    It will eliminate the regular split point that stops the rears getting additional clamping above a certain pressure
    It's very likely that's _all_ you need to do
    Thanks good tip, that was also discussed in jaq's link and it sounded interesting…
    Wait, did you say "easiest" and "it can be a pain" in the same sentence?!
  • jaqattack02
    jaqattack02
    • 1185
    #18
    If I were you, I would start with the pad compound and see where that gets you. I don't find mine all that bad, as it only does it when you seriously crank down on the brakes hard. The way the car stops, I can't imagine hitting them that hard unless it was a super panic stop, I've only done it when testing the brakes.
    My 1986 Turbo Build
  • boosted300
    boosted300
    • 195
    #19
    Will definitely be my first step, thanks very much.
  • Rick88ss
    Rick88ss
    • 2433
    #20
    What pads do you have in the front and back now? What rear pads are you gonna switch to?
    Shiro #443
  • frostvectron
    frostvectron
    • 1044
    #21
    FYI, NT01 and R888's are not meant for street use.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • boosted300
    boosted300
    • 195
    #22
    I think I'm gonna go with hawk hp plus in the rear
    Fronts are something called BP-20 I believe.
  • boosted300
    boosted300
    • 195
    #23
    Don't tell that to the GTR crowd down here!
    But technically, yes you're right…but it won't be a problem.
    It's not a daily driver and I don't plan on driving it in the rain anyway.
    I have several friends with GTR's and Supras that run one of those two on their daily drivers with no problem.
    I have Advan A048's on my 240Z which is also a competition tire not for street use and no issues.
  • jaqattack02
    jaqattack02
    • 1185
    #24
    You may also look at going to a Wilwood BP-10 in the front. From what I remember the BP-20 is the more aggressive track oriented pad, while the BP-10 is designed to be for street use with occasional track time.
    buy seeds.
    My 1986 Turbo Build
  • G-E
    G-E
    Junior Member
    • 6320
    #25
    It can be a pain to do the surgery on the master, some use a 5-point allen head screw, others are locktited, but it's "easy" in the sense that you don't have to touch the car's dirty bits
  • NissanEgg
    NissanEgg
    • 5220
    #26
    ^ THIS!
    On my Wilwood Dynalite 4-piston setup on my B13 I use the BP-10 as the street pads for the front. It stops the same as stock and I can lock up the tiny rear drums slightly before the fronts. My track pads are the Poly-Q compound, which is basically a dirt track compound and several grades higher than the BP-20. The BP-20s I used before the BP-10s had more bite and kind of sensitive to initial input for a street pad, which made it kind of jerky/grabby and annoying.
  • boosted300
    boosted300
    • 195
    #27
    To be honest, I'm not positive which pads I have, I forgot! I have to pull one out and look at the number…
    however, they feel very streetable for the most part…after some aggressive braking they feel a little "grindy" almost like metal on metal…which I've always found a little unusual.
    I'll let you guys know as soon as I get a chance to look at them.
    But (assuming I have BP-20's) rather than downgrade the fronts…wouldn't I rather upgrade the rears?
  • adamvann3
    adamvann3
    • 4160
    #28
    I run BP-10 on the Wilwood 4 pot fronts and EBC green stuff in the rear. Seems to be a good balance but the fronts will lock up prior to the rears. However the car doesnt dive forward under hard braking which gives it a balanced feel.
    z31s could really use a simple solution to adapt z32 rear caliper setup. It would balance out a lot of the front brake upgrades widely available.
    A lot of awesome information on here. Quite impressed to see some of the heavy hitters back providing some good insights!
    86na - BlueZ
    85t - Mr Tickles
  • boosted300
    boosted300
    • 195
    #29
    You know I was thinking the exact same thing…I might have missed it, but it seems that's something no one here has really done?
    I have a friend with a pretty radical S130 and he has the Z32 front and rears…I asked him about the rears and he said he just had to make a bracket…
    Is it just not that simple for us?
  • jaqattack02
    jaqattack02
    • 1185
    #30
    I have a simple solution for the z32 rears including keeping the ebrake. The issue is that it uses M30 or R31 skyline parts, neither of which are all that easy to come by.
    My 1986 Turbo Build
