Anyone running 17x10 +20 square setup? or 17x10/18x10.5 stagger
Looking for pics of 17x10 +20 on the Chuki or Kouki model.
or 17x10+20 front 18x10.5 +20 stagger setup?
any issues running this on stock body? (I own a fender roller aswell)
what size spacers are you running (if you are)
thanks!
Axel kainModerator- 1221
10.5 rear is no problem. strut to fender clearance is where you run into issues. 9" fits nicely, but 10 might be interesting…Damn dirty angels....these cars!
sigpic -
jesus94pSenior Member- 892
17x10 +20 is impossible without a spacer up front. I run 1.5" spacers and its flush -
My s13 coilover adapters that move the strut inboard could help here, would let you tuck a bit, and give you more backspace at the same time -
what tire size are you running?Originally posted by jesus94p View Post17x10 +20 is impossible without a spacer up front. I run 1.5" spacers and its flush
if I scrap the short stroke conversion, I am probably just gonna grab a set of stance and be done with it! I don't mind spacers I may just go for a different set of wheels,Originally posted by G-E View PostMy s13 coilover adapters that move the strut inboard could help here, would let you tuck a bit, and give you more backspace at the same time
You will have LESS room using the stance coilovers if you go that route, they are beefy, so you'd actually make it harder for yourself hehOriginally posted by slammedcoupe View Postif I scrap the short stroke conversion, I am probably just gonna grab a set of stance and be done with it! I don't mind spacers I may just go for a different set of wheels, -
^You try to sell those things off to everyone that comes around and I don't see anyone buying them lol. good luck -
When someone says "don't worry I'll just do this instead" which makes life harder, it's not about my products anymore is it?
Although I do mention my products, the reason is to accomplish a goal, if anything I make can help, I'd like to help…
Rustspecs13Senior Member- 283
Fronts are 17x10 +18 with a 25mm spacer, 245/45/17 tire. Rear is 18x10.5 +15 no spacer. 245/45/18 tire in the front yard picture and 275/35/18 in the driveway picture. Also in the driveway picture I have my heim joint rear control arms, so they have only 1.5-2deg of camber changing the wheel fitment and the wider tires. Verses the 3.5-4 it had in the other picture. Fenders are rolled. Rears only needed to be lightly rolled with stock control arms, and fronts needed to be heavily rolled (its flat now) but I also have more steering angle and soft springs.
~Alexsplatter fake blood on fubar'd quarter and roll out.
pedestrians=mobile clipping points -Benedict on PurePontiackid's 280zx -
I see you don't like stretched tires lulz. And i was never talking about my rear setup, only the front, which is flush.
awesome thanks man!Originally posted by Rustspecs13 View Post
~Alex
front looks just about spot on, I want to run 255/40r17 fronts and something larger out back depending on wheel size.
I should add I will be running heim joint f+r control arms when I get around to building them and possibly some steering mods!
